It was recently announced that the planet Mars has at least one thing in common with planet Earth: all good things come to an end. In this case, the good thing is the recently announced and documented (Feb. 12) demise of the Mars rover Opportunity.
Cylindrical gear design can be divided into three steps. In the first step, rough gear pair dimensions such as center distance and face width are being estimated. Center distance and face width are directly linked to the available space (housing dimensions) and influence the overall size, weight and cost of the gears.
Autonomous vehicles (AVs), in particular, are set to utilize sensors for a multiple array of new technologies. In fact, lidar sensors may be the key to unlocking the potential of driverless cars in the future.
By most measures, and according to most observers, the manufacturing economy continues to hum along. U.S. manufacturing has been in growth mode for several years, although the rate of growth has slowed, and most are predicting that it will continue to slow throughout 2019.
