This paper provides an overview of the more common position sensor options and references actual case studies to
illustrate the diverse solutions available and the reasons behind some of the decisions. Three cases are used to illustrate the needs of different applications leading to the choice of a particular type of position sensor. The cases reviewed include a gantry crane, wind turbine and aerial cable car.
The world of high horsepower drives often calls for mechanical design to be approached from different perspectives. As motors, gearboxes and machines increase in size, power density can become disproportionate from one driveline component to the next, emphasizing the need for more rugged, robust and compact equipment.
Many power transmission components require a certain level of customization
for each individual project. The big bearing market is no exception. Construction, mining, steel, marine and
wind applications aren’t exactly areas
where customers buy bearings in bulk.
Manufacturing employees have always kept their eyes on the robotic systems that continue to pop up in assembly lines and industrial workspaces. These metallic, low-maintenance robotic
employees don’t waste time with smoke breaks or catching up on episodes of Lost. They tend to stick to the task at hand with little argument or attitude, giving human counterparts a bad name when they gripe about factory temperatures or lack of a decent dental plan.
The SMMA – Motor and Motion Association is ditching the slickers and galoshes for this year’s Spring Management Conference, themed “After the Storm: Navigating in the New World.”
