SPS-IPC Drives 2011, which took place in Nuremburg, Germany in November, covered all components down to complete systems and integrated solutions in the electric
automation industry.
elements on the machine tool.
Norkol Converting Corporation is one of the nation’s leading independently owned
converters and distributors of commercial printing papers. The company has full production capabilities and state-of-the-art machinery for winding, trimming and sheeting. The company utilizes traditional slitter re-wind equipment that unwinds, slits and then re-winds paper to new dimensions. These conventional re-winders, while typically producing new widths of paper with clean cuts, work at an inefficient, slow pace.
The demand for stepping motors with high efficiency and low losses has been increasing right along with the existing focus on high torque. The selection of the most suitable grade and improvement in the fastening
of the laminated cores has reduced losses significantly at their peak when compared to conventional stepping
motors.
How to select a guide wheel with the properties best-suited for a given application to create a system that reduces design costs and engineering changes, and lowers warranty, assembly, installation and mounting costs.
