Much of the industrial energy being
consumed by systems is wasted through inefficiency. For this article, a system will be defined as the following components working together: electrical input power, variable frequency drives, induction motors, gearboxes and transmission elements
(chains, belts, etc.).
The Magnetic Gearing and Turbine Corp. (MGT), founded by Australian inventor Andrew French in 2000, manufactures injection molded gears and couplings based entirely on magnetic technology. The repulsive magnetic forces are used to transmit power without losing any energy, and drive shafts rotate completely independently of each other.
If you’re replacing your belts more than once per year, it’s time to analyze your drive. From belt crimping damage to high belt installation tension to sprocket misalignment and adverse environmental conditions, this guide walks you through how to identify the reasons behind premature failure and makes recommendations on corrective and preventive measures.
In an industrial application, equipment
uptime is vital for on-time performance and profitability. The rotating members of industrial machines are subject to the highest degree of wear and are more susceptible to failure than non-moving parts. Bearing surfaces are the most critical and often the most expensive portion of the rotary assembly; it is
imperative to protect these components. The primary protector of these components is the industrial seal.
