If you’re replacing your belts more than once per year, it’s time to analyze your drive. From belt crimping damage to high belt installation tension to sprocket misalignment and adverse environmental conditions, this guide walks you through how to identify the reasons behind premature failure and makes recommendations on corrective and preventive measures.
In an industrial application, equipment
uptime is vital for on-time performance and profitability. The rotating members of industrial machines are subject to the highest degree of wear and are more susceptible to failure than non-moving parts. Bearing surfaces are the most critical and often the most expensive portion of the rotary assembly; it is
imperative to protect these components. The primary protector of these components is the industrial seal.
Robotics and other advanced automation technology systems are viewed as a looming threat to some in the plant
maintenance field. Although there is
a constant battle for some workers to
remain useful while machines are continuously fulfilling more roles on the plant floor, there are those who in turn have found a better use of their newly freed time.
Nitinol 60 (60NiTi), an intermetallic nickel-titanium alloy containing 60 wt % nickel and 40 wt % titanium, is shown to be a promising material for oil-lubricated, rolling and sliding contact applications such as bearings
and gears.
