While it is valid to state that energy
efficiency is defined as the same level of production being achieved at an overall lower energy cost, it is equally important for today’s machine builders and automation engineers alike to remember that an energy-efficient system can actually translate into higher productivity. This is achievable through a comprehensive approach to energy management.
When your $100 “Rolex” falls apart on your wrist, well, what did you expect? But when bogus bearings find their way into safety-sensitive applications, lives are at stake.
motors with premium efficiency counterparts presents businesses with a significant opportunity to reduce operating costs. A comparison between premium and standard efficiency motors from 0.25 to 10 horsepower is conducted; comparisons of full-load efficiencies are shown, and estimated payback periods are calculated. Methods for calculating the yearly kilowatt-hour consumption and yearly cost savings of premium efficiency
motors for this horsepower range are also given. The cost advantages of premium efficiency motors are summarized, and relevant examples of real world cost savings are shown.
In keeping with a national push to bring greater energy efficiency to wastewater treatment plants, a Pennsylvania facility used data loggers to analyze motor utilization, a first step toward cutting energy costs and meeting environmental rules.
Much of the industrial energy being
consumed by systems is wasted through inefficiency. For this article, a system will be defined as the following components working together: electrical input power, variable frequency drives, induction motors, gearboxes and transmission elements
(chains, belts, etc.).
The Magnetic Gearing and Turbine Corp. (MGT), founded by Australian inventor Andrew French in 2000, manufactures injection molded gears and couplings based entirely on magnetic technology. The repulsive magnetic forces are used to transmit power without losing any energy, and drive shafts rotate completely independently of each other.
