The Flexibility Factor
A Closer Look at Huco Oldham Coupling Customization
A flagship coupling in the Huco range, the Oldham solves the problem of side forces due to misalignment. Misalignment couplings that bend or flex do cause some side loading on bearings and shafts as the coupling tries to spring back. Of course, over prolonged use this can result in rapid deterioration of bearings, extra load on the motor, and eventual coupling fatigue.
The Oldham coupling design accommodates misalignment by allowing sliding between metal hubs and a plastic disc so not to create any lateral forces. This effectively protects equipment from the side loads, improving reliability. Discs are made from engineering plastics and are replaceable and interchangeable for different properties. Standard discs are Acetal, for strength, but Nylon discs can also be chosen for resilience, or damping properties. PEEK discs are sometimes chosen to insulate against electric current leakage or heat transfer. Furthermore, the disc can provide overload protection, as it will break under extreme load to protect associated equipment. The Oldham’s three-piece construction allows easy assembly and installation too. While a general-purpose coupling, the Oldham is particularly suited for use in stepper driven positioning, as it handles high torques while still delivering high accuracy.
“Various available Oldham coupling disc materials provide users with the flexibility to tailor a coupling to meet their specific application requirements,” said David Lockett, Huco managing director.
Custom Demands
The precision applications that Huco’s couplings are designed to fit demand a high level of specialization. The design of a motion systems in, for example, medical devices or food production lines varies greatly, so a ‘one size fits all’ approach isn’t optimal for precision couplings. The coupling may have to fit a predetermined shaft size or operate within the constraints of existing device packaging. To meet this need, Huco can extensively customize couplings to meet unique requirements.
