Sulzer Launches Pump Energy Optimization Solution
Sulzer has launched the Sulzer Energy Optimization Service, an energy efficiency and carbon reduction service that will create a new best practice standard for the operation of centrifugal pumps across their lifecycle for energy intensive industries such as power generation, oil and gas, chemicals and water desalination.
Launched to address growing demand for industrial energy efficiency, the solution brings together digital analysis, machine learning and ongoing monitoring with Sulzer’s decades of engineering expertise to drive down carbon emissions, enhance reliability, and reduce energy costs. A 1 percent increase in global pump efficiency would save around 59TWh of electricity – equivalent to New Zealand’s annual power needs; some pumps’ efficiency could be increased by as much as 20-30 percent.
Announcing the solution, Ravin Pillay-Ramsamy, services division president at Sulzer said, “Inefficient and unreliable pumps cost operators in the industrial sectors millions of dollars in unnecessary downtime, energy costs and carbon emissions every year. Sulzer Energy Optimization Service offers a comprehensive solution that tackles this inefficiency – from identification through to improvement and monitoring. A pilot customer in Spain will now save 1 million in energy costs and over 2,300 tonnes of carbon dioxide a year as a result of energy optimization improvements identified by the service. By rerating five pumps, energy efficiency increased from 72 to 83 percent saving the operator 5,000 MWh in electricity every year.”
Consisting of four steps, an initial pump energy audit identifies areas of inefficiency with Sulzer’s proprietary calculator – PumpWise – outlining the potential energy, carbon and monetary savings.
A tailored proposal is generated by Sulzer’s expert team presenting a range of options to return the pump to run at its best efficiency point through an engineered retrofit, with varying techniques such as hydraulic re-rates, specialized coatings, wear clearances and more. Each option weighs operational costs, investment, downtime, payback and efficiency guarantees. The upgrades are then implemented with support from Sulzer’s established retrofit team which has delivered more than 4,000 retrofit projects globally since its setup in 2010. The team is supported by a network of more than 120 service locations globally.
Post retrofit, Sulzer offers a performance agreement to maintain optimized reliability and efficiency. This includes access to Blue Box, Sulzer’s proprietary machine learning technology which turns pump performance data into actionable insights.
