The gear and gear drive segment of mechanical power transmission continues to focus on performance, reliability and safety. There are several new products offering increased load capacity, reduced friction and longer service life. For those components unable to keep up with industrial demands, there’s a gearbox MRO team waiting to handle emergency repair services. Here’s some of the latest updates from the Power Transmission Engineering website:
NORD Gear Units Offer Flexibility for Heavy Duty Applications
NORD DRIVESYSTEMS MAXXDRIVE and MAXXDRIVE XT industrial gear units offer highly configurable, complete solutions that are specifically tailored to application needs with 11 case size options, a wide range of components and add-ons, and the ability to be configured with 2,3, or 4 gear stages. These gear units provide the necessary power in heavy duty applications such as conveyor belt systems, mixers, agitators, crushers, and bucket elevators.
All MAXXDRIVE housings are optimized for strength, rigidity, and high axial and radial load capacities to withstand the tough environments and loads they are often put under during operation. All bearings and sealing surfaces are machined in a single process for quiet operation and reduced wear over time. The MAXXDRIVE XT design is further enhanced with a larger surface area by way of innovative cooling fin geometry. This allows for increased heat dissipation efficiency, maximizing thermal ratings and effectively eliminating the need for auxiliary cooling systems.
The internal gear components of MAXXDRIVES are hard-finished and rated to international standards. All components are produced in-house at NORD manufacturing facilities to ensure the highest level of quality is achieved. MAXXDRIVE units also feature large roller bearings that increase load capacity, reduce friction, and provide a long service life for components.
