Manufacturing Automation Material Handling Robotics Components Product News Efficiency Energy Efficiency Load Optimization Assembly Assembly
Kuka Robotics KR Titan Ultra Provides Secure Performance for Heavy-Duty Applications
Kuka Robotics announced a new addition to its product portfolio with the KR Titan ultra robot. Designed for load intensive automation applications, the robot combines extensive reach with precise dynamics ideal manufacturers the automotive, battery/electromobility, and large part handling, as well as heavy logistics sectors.
The KR Titan ultra’s mechanical design supports stable motion during high-payload operation. The robot’s kinematics and structural rigidity are optimized to support accurate path control across a wide range of projects. The KR Titan ultra weighs 4.6 tons and carries a payload of up to 1,500 kg and a reach of up to 4,200 mm, depending on the specific application. This allows the robot to withstand lifting various difficult-to-lift parts, including battery packs, car chassis, engine blocks and other large components.
The KR Titan ultra’s versatile geometry allows for the efficient use of available floor space, supporting deployment in new installations and retrofit scenarios. It’s also compatible with Kuka’s controller technology for easy integration into automated production environments that require connectivity with modern safety systems and digital manufacturing workflows. The mechanical components of the robot are designed for continuous industrial operation, with a focus on maintaining uptime and reducing maintenance demands over the lifecycle of the robot.
kuka.com
