Revolutions
January 17, 2023
Automation Motion Control Chain Chain Drives Conveyor Drives Gear Drives Sensors IIoT Predictive Maintenance Revolutions
The strength of predictive maintenance is to anticipate breakdowns. This avoids any costly stoppage of the production line. If predictive maintenance is emerging, it is because it is now possible to capture weak signals on machines.
The only thing left to do is to bring the data up and analyze it. These analyses make it possible to increase customer satisfaction and generate savings.
In the context of industrial automation, this is characterized by the use of sensors, which are the basic elements of acquisition and of data acquisition and control systems (SCADA). They allow the transformation of physical quantities (temperature, pressure, position, concentration, others...) into signals, most often electrical, which provide information on these quantities. These sensors allow a production line to dialogue and to adapt the production tool to the different needs, in a non-exhaustive way, the needs of the markets or the modifications of the customers, but also the maintenance.
The anticipation of breakdowns is made possible by: The implementation of sensors. They allow the capture of several thousands of data points per day. This is what we call the Internet of Things (IoT).
- The modeling of a failure pattern. Based on the operating history of the machines, beyond the symptoms, it is possible to identify the root causes of the failure.
- The development and optimization of predictive algorithms that determine alert thresholds. This is automatic learning or "machine learning."
Predictive maintenance can improve several performance indicators:
- Improving the overall efficiency rate (OER) of equipment
- Reduction of repair and intervention costs
- Improvement and predictability of product quality
Predictive maintenance coupled with the Internet of Things could save companies $630 billion by 2025.
With an annual growth rate of 22%, predictive maintenance investments are expected to win over new industrial players. Iwis is working on predictive maintenance technology for drive and conveyor chains.
iwis.com
