Design Applications Automotive Components Gearboxes Technical Articles Power Power Loss Simulation
General Modeling Method of Power Losses in Transmission with Parameter Identification
In this paper, the models for different power loss sources in transmissions from literature are applied and compared, which form the two methods - ISO 14179-2 and the joint model to estimate the power losses in a transmission. A 2-speed transmission in an electric vehicle is used as a case study to compare the two methods and validate them with experimental data.
This article appeared in the October 2019 issue.
