Realistic Load Spectra Conditions are Essential for Optimal Gear Design
Creating load spectra
The FVA-Workbench offers extensive options for creating load spectra. For example, load levels (speed, torque, frequency) can be input manually or imported directly from a .csv file.
If load spectra are not available, synthetic load spectra can be created for initial analyses and preliminary designs. There are also a number of options for determining load spectra, for example from measurement data of single or multiparametric time level counts, or by creating a rain flow matrix.
For bench tests, test times can also be reduced by omission and truncation, as long as the type and amount of damage are kept as similar as possible. These methods are based on the results of FVA Project Series 485 (LDA+).
