This paper presents a physically grounded calculation method to determine the
efficiency of worm gear drives. This computation is based on the Institute of Machine
Elements, Gears, and Transmissions (MEGT) tribological simulation, which can determine
the local tooth friction coefficients (Ref. 1). With this knowledge other power losses such
as the bearings, oil churnings and seals power losses can also be calculated.
Introduction
Worm gears belong to the cross axis drives; with them a very
high gear ratio can be realized in one stage. But this advantage
is coupled with a high sliding velocity between the meshing
gear teeth. Therefore the tooth friction and also the tooth
friction power losses are higher than with other gear variants.
By the construction of gear solutions it is important to know
their future efficiency. Previous calculations can help engineers
to compare the different solution principles with each
other and to choose the best variant. In this case, a singleworm
gearbox competes with a complex multi-stage, helical
gear/bevel gear transmission. By the last variant, more
responsible empirical equations exist to predict the power
losses in all stages (Refs. 2–4). Unfortunately the standardized
empirical calculation method (Ref. 5) for determining the efficiency
of worm gear drives is not useful if the gear ratio differs
from 20.5. Another disadvantage of this calculation is that
it ignores the variation of lubricant oil and surface roughness.
These omissions complicate the prediction of the efficiency
of worm gear drives. At the University of Kaiserslautern, a
calculation method to determine the tribological behavior of
worm gear drives has been developed. This method is able
to calculate the local tooth friction and thereby the efficiency
of the gear meshing. Taking into consideration the other loss
components in the gearbox, the efficiency of the complete
gear unit can also be calculated. This calculation method is
presented in detail in this paper.
Power Flow in Worm Gear
Drives
Worm gear units are very compact;
a single gearbox includes only two
shafts with the coupled worm and
worm wheel, bearings, seals, and
oil sump. These machine elements
cause power losses in the transmission.
Therefore the losses in worm
gear drives can basically be traced
back to four reasons; tooth friction Pltf;
oil churning Plchur; bearings Plbear; and
shaft seals Plseal losses. The potential
loss sources in a worm gearbox and the power flow assigned
to the Shafts 1 and 2 in a worm gear drive are illustrated in
Figure 1. To determine these power losses it is necessary
to know the local loads of every machine element. The loss
sources can be divided into load-dependent and no-load-dependent
components. Load-dependent power losses are the
tooth friction power losses and the bearing power losses. But
the latter has also a no-load-dependent part. Other no-loaddependent
power losses are the churning and the shaft seals
power losses. In the next section the determination of power
losses is described.
Figure 1 Power losses and power flow in a worm gear unit.
Tooth friction power losses. To determine the tooth friction
in worm gear drives, a tribological calculation method has
been developed at the Institute of Machine Elements, Gears,
and Transmissions (MEGT), University of Kaiserslautern
(Ref. 1).This simplified tribological model of the tooth meshing
by worm gears is shown in Figure 2.
Figure 2 Simplified tribological modeling of tooth meshing by worm gear drives.
The first step of this calculation is determining the contact.
Worm gear drives have a line contact. Several points of the
current contact line are calculated by a solution of the “equation
of meshing.” According to the equation of meshing, the
normal vector of the common surface is perpendicular to
the relative velocity vector of the bodies at the contact point
(Ref. 6). Between two calculated contact points of a single contact line — according to Niemann — the tooth flanks are
substituted by rolls whose radius coincides with their reduced
radius of the curvature, and the rolls perform rotational
motion of the same or opposite direction as the velocity
valid for the given contact point. If the pressure mound above
the flattening was approached according to Hertz, then the
oil film thickness between the pairs of rolls can be calculated
analytically (compare Figure 2). Because worm gear drives
are usually working under mixed lubrication, it is necessary
to determine the local proportions of the dry and fluid friction
mechanisms. It is estimated with pre-computed division
curve, which represents the rate of boundary lubrication depending
on the dimensionless film thickness. The generation
of this curve is based upon the statistical description of the
representative roughness profiles of the tooth flanks and the
contact mechanics (Ref. 1). With knowledge of the film thickness
and the rate of boundary lubrication, the load distribution
along the contact lines can be calculated iteratively. This
technique was developed by Bouché (Ref. 7) and is based on
the special wear properties of worm gears with full contact
pattern. In the next step of the simulation a mixed friction
coefficient between a pair of rolls is recorded. The friction between
the teeth generates heat rise. Therefore both the contacting
surfaces and the oil film between them are heated by
friction. The calculation of the surface temperature is based
on the numerical solution of Fourier’s law for heat conduction.
Our solution-technique is founded on Plote’s method
with Fourier integrals (Ref. 8). The oil temperature in the contact
is calculated according to the simplified energy equation
of the oil film. To calculate the surface
temperatures and the oil middle temperature,
the Fourier and the energy
equations are solved simultaneously.
Knowing the distribution of the oil
temperature, an oil viscosity and an
oil film shearing can be calculated as
well. This shearing is two-dimensional
in the gap by worm gear drives. By
integrating the shear stress along the
penetration surface, the frictional force
arising from hydrodynamic lubrication
can be elaborated. In mixed lubrication,
the friction coefficient consists
of a component arising from boundary
lubrication and one arising from
hydrodynamic lubrication. These components
are weight by the abovementioned
division curve and so the coefficient
of the mixed friction is already
known. As this value was freely chosen
at the beginning of the thermal calculation,
the last computation steps must be
repeated in an iteration loop until the
error is acceptable. After this calculation
the local parameter — for example,
oil film thickness, contact pressure, surface
temperatures and the coefficient of
the tooth friction — are known.
To analyze the efficiency of the worm gear drives the average
coefficient of the tooth friction was determined in every
meshing position. In this paper a ZK profile worm gear drive
with a = 100 mm center distance and i = 20.5 gear ratio was
analyzed. Figure 3 shows the calculated local tooth friction
coefficients above the meshing field and their average value
above the meshing position. In this case the input driving
speed was n1=1,500 1/min and the output torque T2 = 500 Nm.
Mineral oil lubrication was used with viscosity class ISO VG
150 by sump temperature ϑs = 60°C.
Figure 3 The calculated local tooth friction coefficient above the zone of contact (left); the average tooth
friction coefficient computed from this; further the gear meshing efficiency above the meshing
position (right) derived from latter.
Figure 3 represents that the local coefficient of the tooth
friction is changing strong along a single contact line (the
same color belongs to the same meshing position of the
worm). It assumes its maximum value at the middle of the
tooth where the sum velocity is nearly zero and therefore the
boundary lubrication dominates. The average coefficient of
the tooth friction μtf is also changing strongly depending on
the meshing position of the worm φ1. The curve of the gear
meshing efficiency ηmesh follows the change in the average coefficient
of the tooth friction with the reverse trend. It can be
calculated by using Reference 9:
γm is the lead angle of the worm and α0 stands for the pressure
angle. In the knowledge of the gear meshing efficiency
the input torque T1 of the gear pair can be calculated. In the
next step, based on the technical mechanic, the bearing reaction forces can be determined. By worm gear drives by both
shafts generally adjusted bearing arrangements were used.
The additional pre-stress load of the bearing is computed according
to (Ref. 10).
Bearing losses. Knowing the radial and the axial bearing
forces and the rotational speed of the shaft the power loss
torque by each bearing can be estimated according to the
four source friction model of the SKF company (Ref. 10). This
determines the total friction moment in a bearing Ml,bear as a
sum of the rolling frictional moment Mrr, the sliding frictional
moment Msl, the frictional moment of seals Mseal and the frictional
moment of drag losses Mdrag:
The details of their calculation are described (Ref. 10); this
method was used by all four bearings of the gears to determine
the bearing power loss.
Oil churning power losses. At the mechanical engineering
department of ECAM, a physically grounded calculation procedure
was developed to determine the churning power loss
of a pinion, which immerged in an oil sump (Ref. 11). A similar
method by worm gear drives is unknown; therefore the
mentioned calculation is also used in this paper to estimate
the drag torques Ml,chur:
Where ρoil is the oil density, n the rotational speed of the
pinion, A the wetted surface area of the pinion, dm the pitch
diameter of the pinion and Cm the dimensionless drag torque
coefficient, which can be calculated as follows:
Here h means the submerged depth of the pinion, V0 the
oil volume, Fr the Froude and Re the Reynolds number. Both
equations are given in the convention used with SI units.
Shaft seals power losses. To determine the frictional loss
torque of the seals Ml, seal, the following simple equation according
to Ref. 12 was used:
Where dshaft is the diameter of the shaft, bcontact is the contact
width of the sealing, μ is the coefficient of the friction in the
sealing contact and pa is the average contact pressure in the
sealing contact. At this point the use of the SI units becomes
necessary.
Energy balance of the worm gear unit. In the knowledge
of every loss component calculated with the presented methods,
the efficiency of the worm gear drives can be determined.
This calculation is based on the energy balance of the
worm gear unit. It expresses that the sum of the input power,
the output power and the power losses is zero (compare Figure
1). Based on this principle of energy conservation, the efficiency
of the worm gear unit can be calculated as follows:
Here the power of the worm Pworm is increased with the
power losses of the input shaft; this sum corresponds with
the input power of the gearbox. The power of the worm wheel
Pwheel is reduced with the power losses of the output shaft; this
sum is the output power of the gearbox. Both the power of the
worm and the power of the wheel were calculated during the
tribological simulation of the worm gear drives.
Figure 4 Changing of the input and output torques (left); and changing of the efficiency during the iteration (right).
Influence of the power losses on the power losses. The developed
tribological simulation of worm gear drives can only
determine the tooth friction power losses of the gearbox. The
other power losses, such as the bearings, oil churnings and
seals power losses reduce also the output power. Therefore
a higher input power than used at the beginning of the tribological
calculation is needed to cover the necessary output
power of the gearbox. It means that an iterative calculation
must be used to determine the real operational condition of
the worm gear unit. Figure 4 shows the changing of the input and output torque
and the changing of the
efficiency during this
iteration process. It can
be seen that in the first
calculation step the output
torque of the gearbox
reduced by losses is
smaller than the necessary
value T2 = 430 Nm.
In the second iteration
step the input torque
was increased with the
loss torque, which was
calculated in the first
step, whereupon the determined
output torque
is approximately equal
with the necessary value.
After four iteration
steps the calculated output
is exactly equal with
the expected torque.
Nevertheless, the last
two iteration steps are
unnecessary from a
practical point of view.
Using the corrected torques in the second iteration step has
little influence on the efficiency as well. The efficiency of the
gear meshing is slightly decreasing and the efficiency of the
gearbox is slightly growing.
Figure 5 Flow chart of the calculation of
the gearbox efficiency.
Summary of the described calculation procedure. At this
point a short overview about the developed simulation method
will be given to determine the efficiency of worm gear
drives. The calculation process is illustrated in Figure 5. In the
first step of the analyses the local tooth friction coefficients
of the worm gear drive were calculated according to (section
Tooth friction power losses). Afterwards, from the local tooth
friction coefficients the average tooth friction coefficient was
determined, which belongs to the current meshing position.
With this knowledge the gear meshing forces and the bearing
reaction forces are calculated based on the static equilibrium
equations. With the mentioned method in (sections Bearing
losses; Oil churning power losses; and
Shaft seals power losses), the additional
power losses such as bearings, oil
be also estimated. These power losses
modify the input and output torque
of the gearboxes; therefore a new tribological
calculation is necessary. If
the accuracy of the iteration process is
acceptable, the calculation procedure
can be stopped and the solutions can
be put out.
Comparison of the Measurement and the
Simulation
To validate the developed calculation method, a test bench
was built at the laboratory of MEGT to study the efficiency of
worm gear drives. During the experiment the input and output
torques and speeds were detected by different operational
conditions. Figure 6 shows the comparison of the efficiency
calculated from the measured values and the simulated average
efficiency of the abovementioned ZK-type gearbox by the
load T2 = 430 Nm, and by the sump temperature ϑs = 60° C. The
simulated curve of the efficiency concurs very well with the
measured values, so the developed simulation technique can be used as a reliable calculation method to determine the
Figure 6 Comparison of the measured and simulated efficiency of
the analyzed gearbox.
Analysis of Power Losses
The presented, physically grounded calculation method to
determine the efficiency of worm gearboxes has a singular
advantage compared to conventional empirical equations.
While the latter differentiate only between the load-dependent
and no-load dependent power losses, the presented
calculation method separates also between the power loss
sources. This enables engineers to not only estimate total
power loss but also to better understand every power loss
source. Thus it is possible to optimize the gearboxes and reduction
of losses.
Figure 7 Power loss components of the worm gear drive above
Figure 7 shows the course of all four power loss sources
during one rotation of the worm by the load T2 = 430 Nm, and
by the input rotational speed n1=1,500 1/min. Depending on
the meshing position, the tooth friction power loss changes
strongly similar to the changing of the tooth friction coefficient
in Figure 3. Its average value is ca. three times higher
than the second largest power loss — the sum of the four
bearings’ power losses. This is also three times higher in the
investigated operational point than the oil churning losses.
The smallest share has the sum of the three shafts’ seal
power losses. For further analysis of the power sources the
power losses were divided into two groups, depending upon
the location of their generation. Figure 8 shows the power
losses by the input (left) and by the output shaft (right). It
also shows that the power losses by the output shaft can be
ignored compared with losses of the input shaft. The noload-
dependent character of the oil churning and the shaft
seals power loss should also be easily recognizable (Fig. 8).
The high value of the bearing power losses can be explained
with the high axial force component of the bearing reaction
force and with the high rotational speed of the worm. In the
investigated case the worm submerged fully in the sump;
therefore the churning loss was accordingly high, whereas
the wheel teeth were slightly immersed in the oil sump.
Figure 8 Power loss components of the worm gear drives by the input (left) and the output
shaft (right) above the meshing position
This brief study shows the potential for increasing the efficiency
of worm gear drives through reducing the tooth friction
power losses and reducing bearing power losses by the
worm. The first is possible through the optimization of the
gear geometry, reducing the surface roughness, and using
adequate lubrication. As for the second, a good bearing concept
can be helpful.
Conclusion
The comparison between the measured and the simulated
efficiency of the investigated gearbox has shown a very good
concordance. It means that the described, complex calculation
method can reliably predict the efficiency of worm gear
drives. This simulation is also suitable to analyze each loss
component of gears, and therefore can help engineers to optimize
drive solutions.
Balázs Magyar received his PhD in mechanical engineering
in 2012 at the University of Kaiserslautern, and then joined
the University the following year as a junior professor
of tribology. His current research interests include
the tribology of worm gear drives, bearings and shaft
seals. Magyar is now teaching machine elements and
engineering tribology.
Bernd Sauer holds a PhD in mechanical engineering from
Technische Universität Berlin. From 1987–1998, he has
as chief engineer for various companies headed up their
development departments in the high-speed rail industry.
Since 1998, he has served as full professor and head of the
Institute of Machine Elements, Gears, and Transmissions
at the University of Kaiserslautern. His current research
interests include the dynamics and tribology of bearings,
seals and chain drives. Sauer since 2015 has led the Society
of Product and Process Design at the Association of German
Engineers (VDI).
References:
Magyar, B. “Tribo-Dynamische Untersuchungen von
Zylinderschneckengetrieben,” PhD Thesis, University of
Kaiserslautern, 2012.
Doleschel, A. “Wirkungsgradberechnung von Zahnradgetrieben in
Abhängigkeit vom Schmierstoff,” PhD Thesis, TU München, 2003.
Klingenberg, J. Kegelräder. Springer-Verlag, Berlin, Heidelberg, 2008.
DIN 3996:2012-09: “Calculation of Load Capacity of Cylindrical Worm
Gear Pairs with Rectangular Crossing Axes,” (in German) Beuth-
Verlag, Berling, 2012.
Litvin, F.L. and A. Fuentes. Gear Geometrie and Applied Theory,
Cambridge University Press, Cambridge, 2004.
Bouché, B. “Reibungszahlen von Schneckengetrieben im
Mischreibungsgebiet,” PhD Thesis, Ruhr-Universität Bochum, 1991.
Plote, H. “Zur Berechnung Thermo-Elasto-Hydrodynamischer
Kontakte,” PhD Thesis, TU Clausthal, 1997.
Steinhilper, W. and B. Sauer. Konstruktionselemente des
Maschinenbaues 2, Springer-Verlag, Berlin, Heidelberg, 2008.
SKF Rolling bearings Catalogue 10000/EN, October 2012.
Changenet, C. and M. Pasquier. “Power Losses and Heat Exchange
in Reduction Gears: Numerical and Experimental Results,” 2nd
International Conference on Gears (VDI Berichte 1665) pp. 603-613.
VDI-Verlag, Düsseldorf, 2002.
Tietze, W. and A. Riedl. Taschenbuch Dichtungstechnik, Vulkan-Verlag,
Essen 2005.
