SMT's latest webinar "MASTA Support - Tips, Tricks and FAQ" will take place May 4, 2022. The SMT customer support team receive queries covering all areas of MASTA, with industry 'hot topics' inevitably arising. In this webinar, SMT engineers focus on answering some of the queries that frequently make it into their support inbox.
At Automate 2022, attendees will have the opportunity to experience how complete, end-to-end automation solutions from KUKA Robotics can help them exceed their production goals.
Hexagon’s Manufacturing Intelligence has released a comprehensive report entitled "Recharging the Automotive Market." The body of work was produced by Hexagon and draws from the original research conducted with Wards Intelligence and Informa Tech Automotive Group (ITAG).
Manufacturing is facing constant challenges stemming from labor shortages and disrupted supply chains to productivity declines and the high replacement and maintenance costs of legacy equipment. Trends today include equipment upgrades, e-commerce, a push for more robotics and automation and faster software and IIoT solutions.
If torque conversion with high gear ratio, compact installation space and 90-degree axis-crossing angle is needed, often worm gears are used. Due to their high power density and sliding speeds within the tooth contact, frictional heat and thermal stresses are higher compared to helical, bevel and hypoid gears, and thus the thermal load capacity of worm gears is lower.
As concerns surrounding the environmental impact of fossil fuels continue to grow, so does the need to produce vehicles with higher overall efficiency. The importance of enhanced vehicles has spurred drivetrain component manufacturers to study every aspect of efficiency loss in their products. The gearbox is a key contributor to the overall drivetrain efficiency.
