Energy’s
endless energy efficiency
game of whack-a-mole, motors have historically always been one of the go-to moles. They’ve been in the spotlight since 1992. Over the past few decades, repeated efficiency laws have seen motor efficiency get whacked into tighter and tighter shape.
This three-part series on motor management best practices focuses on the importance of instituting a motor management plan as a necessity in effectively administering the electric motors in a facility. The goal of a motor management plan is to take advantage of opportunities for energy savings and increased productivity using energy efficient, reliable
motors such as NEMA Premium efficiency motors, herein referred to as “premium efficiency” motors.
finished products.
The secondhand on the Doomsday
dial ominously spins around the face,
slowly but ever so surely inching the
motor industry towards its inevitable
terminus:
