Over the past few decades, energy efficiency in motors has become an ever-increasing concern for OEMs and
manufacturers alike. With multiple
energy bills mandating higher efficiency across ever-broader spectrums of motors, including the most recent Small Motor Rule by the Department of Energy, efficiency has become an essential consideration when choosing a new motor.
According to the Department
of Energy (DOE), more than
half of all electrical energy
consumed in the U.S. is used
by electric motors. To address
this, several years ago, the DOE conducted
a technical study as to what
could be done to raise the efficiency
levels of “small” motors. After years
of study and litigation, the Small Motor Rule (SMR) was passed that covers two-digit NEMA frame single- and three-phase ¼ through 3 horsepower
motors in open enclosures.
Electric motor-driven systems
are the single largest enduser
of electricity, accounting
for over 40% of global consumption
according to the International
Energy Agency.
Finding picture books for kids old enough to appreciate them can be a daunting task. There are, of course, the usual suspects--celebs, athletes, boy bands, girl bands, and so on, but not much of substance. That's where David Janosz Jr. enters the picture.
The purpose of DC motor protection is
to extend a motor's lifespan by protecting
it from conditions that can damage the motor's windings--both electrically
and mechanically.
