With over 200 years of combined experience, Interact Analysis is the market intelligence authority for global supply chain automation. Our research covers the entire automation value chain – from the technology used to automate factory production, through inventory storage and distribution channels, to the transportation of the finished goods. The world’s leading companies trust us to surface robust insights and opportunities for technology-driven growth.
Applied Flow Technology (AFT) has expanded their team with the hire of two new engineers and one software developer to join their pipe flow modeling team.
As shippers and logistics handlers continue to struggle with supply chain delays, Mitsubishi Gas Chemical America recently introduced the RP System to the North American market to protect critical components from moisture and oxygen damage that can occur during shipping and long-term storage. Manufactured in Japan, this unique packaging solution is designed to safeguard electronics, automotive parts, and industrial components from rust and oxidation.
Cortec Corporation is proud to be named a BioPreferred Program Champion. Cortec recently received this badge of honor in recognition of its involvement and faith in the USDA BioPreferred Program, which celebrates its 20th anniversary this year.
GWJ Technology GmbH has extended the output option of tooth forms of involute gears. GWJ has extended the output of tooth forms in 2D DXF format in its calculation modules single cylindrical gears, cylindrical gear pairs, planetary gear trains, three- and four-gear train systems, gear racks and involute splines as part of the new versions of its calculation solutions eAssistant and TBK.
Cortec Corporation is pleased to announce the development of its latest VCI film and bag technology: CorShield VpCI-220E. The new formula not only offers improved corrosion protection but also includes 30 percent post-consumer recycled content.
NORD DRIVESYSTEMS has announced the latest addition to their industrial gear unit family, MAXXDRIVE XD. These new, parallel shaft industrial gear units have extended center distances engineered specifically for reliable operation of cranes and hoists.
