Randy Stott, publisher of Power Transmission Engineering and Gear Technology magazines, recently sat down with Norm Parker, technical fellow and technical manager for Torque Transfer Systems at Stellantis, to discuss bearing technology during the Motion + Power Technology Expo in Detroit.
NTN Bearing Corporation of America is proud to share its story of support for a local animal rescue. On Thursday, November 16th, NTN donated a Mercedes-Benz Sprinter van with its cargo hold full of supplies to Wright-Way Rescue, but it didn’t happen without a bit of good fortune.
NTN, the parent company of BCA Bearings and Bower Bearings, is proud to announce the receipt of a 2023 Automotive Communications Award from Women in Auto Care. NTN received the award in the “Business-to-Business – Promotional Goods, Gear, Marketing Collateral” category for its BCA and Bower “Summer Cruisin”
Promotions.
The Timken Company has reached an agreement to acquire Engineered Solutions Group (a.k.a. Innovative Mechanical Solutions or iMECH), based in Houston, Texas. iMECH manufactures thrust bearings, radial bearings, specialty coatings and other components primarily used in the energy industry. The business employs approximately 70 people and projects revenue of approximately $30 million for calendar year 2023.
NKE Austria GmbH presents its bearings for railway applications. The bearings are used in traction motors and locomotive gearboxes as well as in railcars, trams and underground trains.
SKF has played its part in securing a new world record: the furthest distance travelled by a prototype motorcycle on a single tank of fuel. The prototype bike clocked up 4,183.8 km on its journey from Albino in northern Italy to North Cape in Norway – without needing to refuel. SKF helped motorcycle components supplier Acerbis in its AC50 project to design the two-wheeler.
VesArg, the Argentinian distributor of Vesconite, Vesconite Hilube and Vesconite Superlube low-friction bearing materials, is proud to announce the acceptance of the Vesconite Hilube needle-bearing kit for the Peugeot Partner and Citroen Berlingo, with VesArg having sold 500 kits for these vehicles in the last two years. This innovative solution addresses the recurring problem of suspension arm issues in these popular utility vehicles, which often require replacement needle-roller bearings.
