A hydro turbine company based in Portland, Maine, has chosen Vesconite Bearings’ lowest-friction material for the thrust bearings on its free-stream turbines.
Regal Rexnord Corporation will feature complete conveying solutions for the craft brew industry including Rexnord and System Plast Run Dry, TableTop and MatTop conveyor chain and Sealmaster Stainless Steel Gold Bearings at the 2023 Craft Brewers Conference, Booth #2625. The show will take place at Music City Center in Nashville, Tennessee, from May 7–10, 2023.
FDA/USDA certified, two, three and four post, stand-off bearing flange blocks are setting a new standard for performance and hygienics. These new stand-off bearing flange blocks now available from LM76 reduce the surface area where mold and bacteria can thrive, even from the most through sanitizing operations. Long life hybrid stainless steel Si3N4 Silicon Nitride ceramic ball bearings in stainless steel bearing blocks are coated with a smooth non-water absorbing polyamide coating certified by EHEDG, USDA, and 3-A. These FDA/washdown flange bearings employ hybrid stainless steel/ceramic ball bearings that are sealed from contaminates and bacteria via a patented shaft seal system. The seals resist water, cleaning solutions - keeping lubrication from being corrupted and evacuated.
Bearing manufacturer NKE Austria GmbH is entering into a strategic partnership with Kugler Bimetal SA, a Swiss producer of bimetallic components and tribological surface finishes. The cooperation was announced at the Hannover Messe in April 2023.
Welcome back to Part 2 of our inner ring and creep discussion. We left off with our creep calculation resulting in a 10.5 µm minimum inner ring fit to avoid creep. For the sake of making clean dimensions, let’s call it 10 µm on the lower end and the upper end is simply whatever your manufacturer can hold.
PTE will feature a variety of new component technologies online for bearings, motors, couplings, brakes, gear drives, and motion control systems leading up to Hannover Messe 2023 in Germany. Here is a preview of some bearings suppliers to check out if you're planning on attending the event online or in-person in April.
Simplicity linear plain bearings exhibit real benefits, when compared to other styles of linear bearings; such as the self-lubricating quality of the bearing’s Frelon liner, as well as the wiping action on the shaft which enables smooth linear motion.
At this year’s Hannover Messe, NKE Austria GmbH will present bearings for wind turbine gearboxes and generators. The Austrian bearing manufacturer has more than 20 years of experience in the wind energy sector. NKE bearings have been installed in more than 4,000 wind turbines across Europe, the USA and China, equivalent to more than 10,000 MW of installed power.
Responding to the agriculture industry’s growing need to increase farm productivity and harvest yields, global industrial and automotive supplier Schaeffler is launching its all-new Field Pro tillage hub in North America. Precision-engineered for maximum output and reliability, Schaeffler Field Pro is the direct-fit, easy-to-install solution that farmers need to help ensure a successful harvest.
