The SKF Generalized Bearing Life Model is (GBLM) an innovative new bearing rating life model that is designed to help engineers calculate bearing rating life in a more realistic manner. The new model is a major step forward for the industry and will play an important role in enabling OEMs and end users to better match bearings and applications, resulting in improved machine life and reduced operating costs.
Power Transmission Engineering (PTE) Has Your Bearing Education, Training, and New Developments Covered Every Issue
February 14, 2017
PTE covers bearings in every issue, from application stories to technical articles and the latest technology from the major suppliers. Here is a selection of some of our most recent and most popular articles on bearings:
End users and OEMs frequently specify
"lubed-for-life" mounted bearings, thinking the lubed-for-life bearings will deliver the same life — without lubrication — as bearings that
currently require periodic lubrication. The truth is it depends on many factors, and only a detailed review of the application and testing will provide a more accurate answer.
a successful business.
In 1991, Needelman and Zaretsky presented a set of empirically
derived equations for bearing fatigue life (adjustment) factors (LFs) as a function of oil filter ratings.
