Ruland has released mountable shaft collars with face holes for applications where the shaft collar needs to be directly mounted to a component such as a pulley, sprocket, or metallic plate. The shaft collars are available with drilled face holes that give the user flexibility in mounting hardware, or tapped holes that match the standard screw threading of the collar for ease of installation.
Portescap introduces the 60ECF brushless DC slotted flat motor, the newest frame size to join its flat motor portfolio and a significant expansion of its brushless flat technology capabilities. This 60mm BLDC motor features a 38.2mm body length and an outer rotor slotted configuration with an open body design, allowing it to deliver improved heat management in a compact package.
China is leading the world in the construction of solar, wind and thermal power plants to support its increasing demand for electrical energy. For those that use steam turbines, boiler feed pumps (BFPs) are a crucial asset and selecting the best design to suit the needs of an individual station can have many benefits. When a recent project needed some of the largest start-up BFPs available, Sulzer was selected as the preferred supplier.
NSK has developed HTF-SRM Ball Screws, a high-speed, heat-resistant version of its high-load drive ball screws, ideal for high-cycle, thin-wall molding in electric injection molding machines.
Boston Gear recently introduced the next generation of its 700 Series Worm Gear Speed Reducer. The SS700 Gen2 stainless steel speed reducer is an evolution of its first-generation series that has served the food and beverage industry for over 10 years.
AutomationDirect has added more ProSense XTH2 series fixed range, head-mounted temperature transmitters to their lineup of temperature transmitters/signal conditioners. The XTH2 series fixed-range transmitters are for Type Pt100 3-wire RTDs and are ready to use out-of-the-box with pre-configured measuring ranges up to 500°F (260°C).
SKF has expanded its portfolio of Condition Monitoring solutions with the SKF Enlight Collect IMx-1-EX sensor solution. Wireless monitoring of assets helps predict machine failure before it can escalate into a serious problem, such as an unscheduled shutdown. This can deliver multiple benefits, including reduced costs and a more sustainable operation of equipment.
Intellidrives Theta 2 theta stage consists of two rotation stages arranged in such a way that axis of rotation for both the stages are same. Both stages have preloaded ball bearing guides for wobble free rotation and positioning. 360° limitless movement is possible for inner and outer stages.
Siemens Digital Industries Software recently released HEEDS AI Simulation Predictor software and Simcenter Reduced Order Modeling software. These tools empower engineers to tackle the most complex challenges manufacturers face, delivering predictive performance with speed, precision, and efficiency.
