Burckhardt Compression recently partnered with one of Europe's leading steelmaking mills undergoing a significant transformation. The mill aimed to convert one of its plants into a sustainable facility in compliance with stringent environmental guidelines. The project's critical aspect involved reviving four non-Burckhardt compressors that had been inactive for a decade. Acknowledging the crucial role of these compressors in steel production, the mill sought the expertise of Burckhardt Compression.
Danfoss is extending the expansion ecosystem. With stable performance, superior operating conditions, and six models to choose from, the EKE 100 range of superheat controllers and valve drivers supports highly reliable system functioning — encapsulating 20+ years of experience in superheat management.
Efficient power-saving braking for mobile robots is critical to minimize battery charging downtime. The new larger size Miki Pulley BXR-LE brakes are ideal for factories and similar applications using mobile robots.
NKE Austria GmbH presents its bearings for railway applications. The bearings are used in traction motors and locomotive gearboxes as well as in railcars, trams and underground trains.
Deutronic has developed a new line of charging computers to supply reliable power to the 12V board net for EV or gas-powered vehicles in multiple environments in the North American market. Company executives Zubin Verma and Tobias Wanzke will preview the capabilities of the DBL 1903-14 charger at the AAPEX automotive aftermarket show, October 31-November 2 at the Venetian Expo in Las Vegas.
Bodine Electric Company introduces six new type 56R1-50JW/H stainless-steel hollow shaft gearmotors. These new geared motors combine a stainless-steel AC inverter-duty, 230/460 VAC motor with a stainless-steel hollow shaft gearhead. When used with an AC inverter (VFD) control, these gearmotors deliver variable speed and maintenance free operation over a wide speed range. Ideal for equipment that is subject to intensive cleaning, these new gearmotors also meet EU hygienic standards for food machinery. They are suitable for use in the food and beverage industry, pharmaceutical industry, and in permanently wet environments.
VesArg, the Argentinian distributor of Vesconite, Vesconite Hilube and Vesconite Superlube low-friction bearing materials, is proud to announce the acceptance of the Vesconite Hilube needle-bearing kit for the Peugeot Partner and Citroen Berlingo, with VesArg having sold 500 kits for these vehicles in the last two years. This innovative solution addresses the recurring problem of suspension arm issues in these popular utility vehicles, which often require replacement needle-roller bearings.
