IKO International introduces its CFC…B Series of short stud-type cam followers. These new cam followers have a unique mounting structure that solves space limitations that often exist on the stud side of the assembly region, thereby satisfying mounting requirements without sacrificing performance.
When it comes to twisting and bunching wire and cable, consistency is key. For example, the amount of insulation required for residential wiring depends on the wire’s lay — the distance between its twists, which is also known as the pitch. Without tight control during the wire bunching process, lay variations occur. As a result, the wire will require more insulation than necessary, raising its cost. A differential gearbox can drive rotating components in a single-twist buncher to provide a more uniform lay, using less power at a lower cost than a two-motor approach.
Igus, a global manufacturer of motion plastics, has developed intelligent two- and four-hole fixed flange bearings with wireless sensing capabilities for wear detection, enabling condition monitoring and preventing costly machine breakdowns.
Caterpillar Inc. has launched a prototype demonstration project for a battery-powered field elevator with Flory Industries, a global leader in the production of nut-harvesting equipment.
Portescap introduces the 08ECP20 brushless DC slotless motor, a mini actuation solution ideal for engineers looking to downsize devices and applications without compromising on performance or reliability. The 08ECP20 is the smallest frame size to join Portescap’s Ultra EC portfolio.
Corrosive chemicals such as chlorine, acids, alkalis and solvents require special pumps to handle their corrosive properties. Centrifugal pumps are most often used and offer advantages during the production process particularly when operating with Stainless Steel ASK Couplings from Miki Pulley.
Mahle will feature products focusing on electric drives and intelligent charging at CES 2024. Mahle's technology kit for electric motors featured at CES 2024 combines the advantages of the company's benchmark SCT and MCT electric motors. With this unique technology toolbox for electric motors, Mahle can offer its customers customized electrification solutions for any vehicle class, application, or even brand philosophy.
