Guy Gendron, certified bearing specialist and technical sales representative at Timken Canada L.P. explains how he used his bearing expertise to increase a customer’s productivity.
Power Transmission Engineering is collaborating with the Bearing Specialists Association (BSA) on a special section within the magazine. Bearing Briefs will present updated reports on bearing topics for each issue in 2016. Complimentary access to all BSA Bearing and Industry Briefs is available on the BSA website at www.bsahome.org/tools. Additionally, our new Field Notes section on page 34 will feature field reports from BSA’s Certified Bearing Specialists.
In 1991, Needelman and Zaretsky presented a set of empirically
derived equations for bearing fatigue life (adjustment) factors (LFs) as a function of oil filter ratings.
Tapered roller bearings can be set at initial machine assembly to any desired axial or radial clearance. This unique feature enables a designer to control bearings to meet anticipated application operating conditions, and thereby provide
optimum bearing and system performance.
