Standard carburizing steel 18CrNiMo7-6 is often used when high hardenability is required, but due to its highly fluctuating price, there has always been an incentive to develop Ni-free steel grades. The 23MnCrMo5-5-2 — or Jomasco 23mod — has been developed for
this purpose. But to ensure smooth substitution within existing production lines, a number of points must be addressed: first, checking the response to carburizing treatments;
and second, having similar mechanical properties with identical tooth root bending performance on gears. The latter is the purpose of this paper.
Gregory (Keith) Boutwell, CBS and executive account manager at B&D Technologies (a division of B&D Industrial), explains how he used his bearings expertise to save a customer thousands of dollars through correct bearing installation.
a successful business.
The manufacturing process begins in a
limestone quarry. Mining methods such
as ripping, dozing, drilling and blasting are commonly employed. Limestone provides the first essential component, calcium, for the anufacture of cement.
Materials are transported to the
crushing plant for further size reduction. Common methods of transport are trucks, loaders and belt conveyors.
Dale Renner, CBS and sales representative at Bearing Headquarters Co., explains how his bearing expertise
helped solve a customer’s problem
and saved significant downtime and
cost.
