Many power transmission components require a certain level of customization
for each individual project. The big bearing market is no exception. Construction, mining, steel, marine and
wind applications aren’t exactly areas
where customers buy bearings in bulk.
While it is valid to state that energy
efficiency is defined as the same level of production being achieved at an overall lower energy cost, it is equally important for today’s machine builders and automation engineers alike to remember that an energy-efficient system can actually translate into higher productivity. This is achievable through a comprehensive approach to energy management.
When your $100 “Rolex” falls apart on your wrist, well, what did you expect? But when bogus bearings find their way into safety-sensitive applications, lives are at stake.
In an industrial application, equipment
uptime is vital for on-time performance and profitability. The rotating members of industrial machines are subject to the highest degree of wear and are more susceptible to failure than non-moving parts. Bearing surfaces are the most critical and often the most expensive portion of the rotary assembly; it is
imperative to protect these components. The primary protector of these components is the industrial seal.
