The air-oil, two-phase flow inside the multiple-point, oil-jet lubrication ball bearing was studied based on CFD (computational fluid dynamics) theory and technique, and compared with single-point, oil-jet lubrication. The results indicate that the air-oil distribution inside the bearing with multiple-point, oil-jet lubrication is more uniform than single-point injection.
For either brand-new motors or those already in service, "best practices" means that informed technicians can make use of the latest diagnostic techniques (vibration analysis, thermography, shaft-voltage testing, etc.) to prevent electrical bearing damage -- either at the very beginning or very quickly thereafter. If done correctly, the work need only be done once.
Recently I had a disturbing conversation with a colleague here at the office. During the conversation, it became clear to me that my co-worker -- a really
intelligent guy whom I respect a lot -- had no idea how even the most simple electric motor works.
