Passenger transport today moves significantly faster than ever before, often operating on separate tracks especially designed for high-speed trains. Accordingly, high-speed rolling bearings are very important components in the bogies of trains today. Maximum train speeds currently reach 380 km/h (236 mph) in the latest high-speed applications - 80% higher than in the earlier days of high-speed traffic. This paper presents two application examples of modern, high-speed traffic, together with some typical bearing arrangements and housings. It provides insight regarding measures taken in the
bearing industry to meet the requirements of contemporary, high-speed traffic, and it cites important standards and regulations
applicable for - but not restricted to - European applications. To be precise, the focus here is on journal bearings; information on traction motor bearings, transmission bearings and housings is included, but described in less detail.
At a Midwestern producer of tubular
steel products, measures taken to counteract the effects of impact on a quench tank roll made it difficult to remove and replace the conventional pillow block bearings that support the roll’s shaft.
The availability of high-strength shaft materials, in combination with bearings with high carrying capacity, allows use of slimmer shafts. However, the modulus of elasticity remains the same, so seat
design for bearings and gears must be given close attention.
Welcome to the first installment of Market Update - a by-the-numbers, in-the-now snapshot of industrial markets worldwide, along with some prognostication to assist in planning
your next moves - when to hold ‘em, when to fold ‘em, etc. Look for Market Update in future issues.
Motion control systems engineers work chiefly in two well-defined areas: 1) new designs and 2) redesigns or retrofits. This article examines the best approach for each option.
elements on the machine tool.
