At first glance, ball bearings are
relatively simple mechanisms. However,
an analysis of their internal geometries
reveals that they are quite complex. For
example, the ball to raceway conformity,
the radial play, and the number of balls all impact the ability of a ball
bearing to support loads under a variety
of conditions.
A new solution has been developed around
the use of microprocessor-controlled
prostheses. Just like natural limbs, these
can react automatically, adapting to the
current situation.
This article takes a look at alternative-material, non-metal bearings, and it turns out the first bearings of that type - wood, in this case, were the
norm - not an alternative.
