After a brief introduction to the importance of gear pumps in internal combustion engines, as well as in the most diverse hydraulic applications, a calculation method was applied that allows for sizing with considerably higher delivery rates. Upon identifying and analyzing a traditional pump, along with two construction solutions of asymmetric gear pumps, we then compared their related performances.
Seems simple enough doesn't it? It is most decidedly not. Indeed, one can make the case that--aside from uppermost management (or ownership)-- no one else in a heavy/high-tech manufacturing concern has more ownership of the company's everyday needs and necessities than the purchasing department.
We are pleased to present our first annual Engineering Showcase, a celebration of some of the leading products and companies in mechanical power transmission. In the pages that follow, you’ll find examples of engineering excellence and technological know-how in the field of gears, drives, couplings, machine parts and other mechanical components.
