First-quarter results are in (bad weather) and summer will prove more interesting than either the market or the fall elections until after Labor Day. But much is happening!
The air-oil, two-phase flow inside the multiple-point, oil-jet lubrication ball bearing was studied based on CFD (computational fluid dynamics) theory and technique, and compared with single-point, oil-jet lubrication. The results indicate that the air-oil distribution inside the bearing with multiple-point, oil-jet lubrication is more uniform than single-point injection.
For either brand-new motors or those already in service, "best practices" means that informed technicians can make use of the latest diagnostic techniques (vibration analysis, thermography, shaft-voltage testing, etc.) to prevent electrical bearing damage -- either at the very beginning or very quickly thereafter. If done correctly, the work need only be done once.
The following news items offer the latest on lubrication and seal technology in the power transmission market. From bearing greases to high-performance seals, these products will help extend the service life and manufacturing capabilities for a wide range of industrial sectors.
Step motors come in many sizes and shapes. But they all share one item in common - each step motor type moves in discrete-degree steps. They react to a series of voltage pulses supplied by their basic controller, known as an "indexer." The step motor was the first to accept digital pulses, then move or rotate a prescribed amount without any feedback device. All step motors are position devices without the need to use any feedback devices. They operate primarily in an open-loop control scheme.
When I woke up this morning, my house was a comfortable 68°F, despite the fact that overnight temperatures in the Chicago area were close to freezing. I don’t often think about the blower motor that helps circulate the warm air from my furnace throughout my house, but today I was grateful for it...
