While the basic design of iron and coke blast furnaces is centuries old, today's steel makers are looking for innovative
ways to produce molten iron with increased production and efficiency
Beginning with a brief summary and update of the latest advances in the calculation methods for worm gears, the author then presents the detailed approach to worm gear geometry found in the revised ISO TR 10828. With that information, and by presenting examples, these new methods are explained, as are their possibilities for addressing the geometrical particularities of worm gears and their impact upon the behavior and load capacity of a gearset under working conditions based on ISO TR 14521 — Methods B and C. The author also highlights the new possibilities offered on that basis for the further evolution of load capacity calculation of a worm gearset based on load and contact pressure distribution.
The Formula Renault 3.5 is seen as a crucial stepping stone on the way into the premier class, the Formula 1. Ambitious racers do not just bring their talents - they also have highly efficient motors on board to control the throttle of their 530-hp V8 engines.
There are three major types of reluctance motors: all three reluctance motors are non-permanent magnet, brushless motors. They are synchronous motors with a non-linear relationship between torque and current. The variable-reluctance step and switched-reluctance motors utilize the principle of magnetic attraction by inducing magnet poles within the soft-iron rotor, and by energizing a set of coils wound around stator teeth resident in the laminated stator. These two reluctance motors must be sequentially excited to achieve continuous, steady-state rotation. The design of all reluctance motors requires finite element analysis (FEA) software.
