More than 27,000 packaging and processing professionals attended Pack Expo 2013 in Las Vegas from September
23–25. In addition to launching new products, creating brand awareness,
achieving sustainability goals and generating new business contacts, Pack Expo was an opportunity to engage the next generation of workers in packaging, robotics and processing
applications.
Dave Soma, the mechanical supervisor at Leland Olds Station, a coal-fired power
plant near Stanton, North Dakota, says he and his maintenance team care deeply
about keeping the plant running and providing people electricity, especially in the dead of winter.
Last month's Gear Expo in Indianapolis provided a great opportunity to meet potential suppliers of mechanical power transmission components -- mostly gears and gear drives, of course, but also a smattering of suppliers of bearings and motors as well.
