The first thing you see when you walk into Winzeler Gear is a pretty face. No, scratch that — the face is beautiful. Streamlined with chiseled cheek bones, delicate yet bold and strong, a half dozen photos of the feminine face line the building’s entranceway, enclosed tastefully in simple black picture frames, beckoning you to come further in with its pleasant warmth, repelling you to turn and leave with its foreign presence in such a location.
A four-point contact ball bearing makes it easy to simplify
machine designs that combine radial, thrust and moment
loads, because it can handle all three simultaneously. They
are primarily used for slow-to-moderate-speed applications,
or where oscillatory movement is predominant.
Bellows couplings first began to be
widely used by machine tool builders
in the mid-to-late 20th century. With the
advent of CNC technology, machine
engineers started looking to improve
upon some of the negative influences
traditional power transmission couplings
can have on a precision rotary /
linear motion system.
John Morehead, national
sales manager of Crouzet Motors
(Vista, CA), was bunkered
down in his office in Palatine,
IL surrounded at all points by
ankle-deep snow from an unfortunately
terrible Chicago’s
winter night.
