Looking at a Gear Cube XXL, you can't help but think about a Rubik's Cube. Both are 3x3 puzzle cubes with brightly colored pieces. Moreover, both are sold commercially as toys.
In planetary gear systems of high power density and high gear ratio, helical gears create undesirable tilting moments on the planet gears; therefore, spur gears are still preferred for planetary gears -- a special challenge with respect to noise. Specifically, the different behavior of planetary gears with sequential and symmetric gear mesh is explained in this paper.
The transverse flux permanent magnet motor -- also known as a hybrid step motor or hybrid servo motor -- has a wide range of performances, depending upon how you drive these motors, and whether you operate them in open loop or one of the many variants of closed loop methods you use. In this third installment we will cover some of the many ways to drive these motors, as well as how these choices affect the performance of these motors.
Many industrial facilities with air-cooled heat exchangers (ACHE) and cooling towers often have older units installed. Depending on the age, repairs, and maintenance done over the years it may have had an impact on performance. Upon conducting site inspections of the equipment, it is sometimes found that ACHE or
cooling tower components have degraded. This can result in a system that is not very energy-efficient and delivers substandard cooling performance.
Digitalization is increasingly transforming mechanical engineering and manufacturing technologies, bringing with it not only unparalleled control and flexibility over production systems but so much more.
