Bosch Rexroth Offers Linear Modules for Lighter Loads
The new SHL lead screw-driven module is designed for light-load, low-cost applications. Made with a 55-mm-wide aluminum frame, the SHL is precise and compact. This module comes with the option of a motor and controller or just the motor, depending on the requirements. The SHL is ideal for college projects, industrial automation, biomedical and other applications.
The new SHB belt-driven linear module is compact, yet robust. It offers stroke lengths up to 2 meters and load capacities up to 110 lbs. centered. The SHB measures 40 mm wide and has a repeatability of
Both the SHL and SHB modules are available with I/O, E-stop ports and cables (-C versions). For more simplicity, there are only two configuration parameters to choose from: stroke length and whether I/O and E-stop ports are required. All the product specifications, stock levels and ordering information will be available on the Rexroth Store Website, making these linear modules easy to access and order online.
