The following short articles first appeared on www.powertransmission.com. They are
part of the ongoing series of hints, technical tidbits and inside knowledge presented
by our resident blogger, Norm Parker. If you like what you see here and are interested
in learning more, visit www.powertransmission.com/blog.
Why Are Cast Iron Housings
More Problematic When
Fitting Tapered Bearing Cups
into Bearing Caps of Salisbury-
Style Axles?
Figure 1 Rear-view Salisbury-style axle.
I was recently approached for the
9,000th time (at least) about fitting tapered
bearing cups into bearing caps.
Bearing caps can be a fairly generic
term, so let me clarify that I am specifically
talking about bearing caps in
a Salisbury-style axle — which are the
majority style of light-duty truck axles
used today.
Figure 2 Bearing cap after machining and removal.
Generally speaking, you don’t want
an interference fit on these bearing
caps because they will distort when
you tighten them down.
For as long as bearing caps have
been around, keeping them round has
been the issue. Typically, the caps will
be mated to carrier and machined as
one assembled pieces. The prevailing
theory was that if the cap bolts were
tightened down enough so that the cap
wouldn’t move during machining, the
cap should be able to be removed and
reassembled with the same tolerances
it was machined to — right? Wrong.
It has been found that after the cap/
carrier interface is machined, the measurements
may be perfect — until you
loosen the bolts for the first time. The
cap will often contract and give you an
out-of-round cap. There are a couple
of theories; I’m of the opinion that the
machining operation imparts some
compressive stress into the machined
surface of the cap which aids in the
contraction when the cap is removed.
How much does the cap contract?
Figure 3 Bearing cup spalling at the cap interface.
It can be substantial. Substantial
enough to fail a bearing at the split line
location. Figure 1 is a cap that was machined
to perfection prior to removing
the bolts and, upon removal, measured
120 μm out-of-round at the split
line location — far beyond acceptable typitolerances.
To make matters worse, the
out-of-round is very localized — creating
almost an edge at the split line.
In testing, this cap wound up failing a
bearing cup as the first failure in the
axle, taking about one-half of the life
out of the axle.
For reasons I don’t yet completely
understand, this problem seems to be
more prevalent in cast iron housings.
Aluminum housings don’t seem to
exhibit this problem nearly as often as
iron housings. It could be because the
AL doesn’t get as hot during machining,
but that is speculation on my part.
We’ll really get into this deeper in a
full article, but for now, keep your cap
fits light. I like to start off somewhere
around a line-to-line fit. There are occasions,
if you are having really bad
contraction with heavy loads, when
you may have to back off farther than
that.
Bolted or Welded Ring Gears? Which and
Why?
There is often a lively debate early in a program when
we are discussing the pros and cons of laser welded
ring gears vs. bolted ring gears. Just about every company
that makes gears has both styles to some extent.
There is no right answer for every application. Mass
savings with welding
often dominates the
conversation, but let’s
take a high level look at
some of the other pros
and cons to consider if
you find yourself if this
conversation.
There are clearly
more check boxes in
favor of the bolted assembly.
However, if
someone if offering up
1kg or more in mass
savings for a welded
assembly, depending on the vehicle, welding very
well may be a worthwhile venture. Looking at the
comparison, it becomes obvious why companies typitolerances cally employ both methods. For high
performance, lightweight vehicles,
laser welding becomes very attractive.
For larger, heavy duty type applications
where mass does not have
as high of a premium, bolting wins
the contest. The upside to welding is
that after you make the investment,
you will always have both technologies
available to suit any application
that comes your way.
Bearing Cup Fits in Aluminum
Housings
Figure 1 Linear Thermal Expansion. NSK Ltd, Cat. No. E728g 2009; p 67.
Editor's Note:
"Bearing Cup Fits in Aluminum Housings" was Part 1 of a three-part series on the
issues of dealing with aluminum housings. It was originally posted on February 13.
Visit www.powertransmission.com to see:
- Part 2, "Cup Distortion After Installation" (Feb. 20).
- Part 3, "Preload Change Due to Bearing Span Change with Temperature" (March 4).
The interference fit that cups should
have in an aluminum housing is a subject
that comes across my desk in regular
intervals. Of course, there are numerous
reasons why you would need
certain fits in different areas. If there is
a bearing cap involved, you may have a
light or loose fit. If you need something
that is going to be serviced at intervals,
you are likely going to want a fit as light
as possible. In gear housings, the highest
priority is often the stiffness of the
system, which drives a cup fit that you
never want to lose contact because the
cups will start to float in the bore, creating
misalignment in the shaft. In a perfect
world we could run a CAE stress
analysis to determine how the cup interferes
with the housing and then run
a thermal study to make sure we hold
our position at peak temperature.
But as a great person once said,
“Ain’t nobody got time for that.”
The bore expansion can be simplified
to a simple diametrical expansion.
It’s not 100% perfect — but its close
enough for our purposes. A perfect calculation
would use the linear expansion
around the circumference, but
when you use the same simplification
for both cup and cone, the end result
is nearly identical as the more elaborate
approach. Using this simplified
equation, a 100 mm bore at 120°C will
expand by 85 μm from room temperature,
25°C. If you were trying to maintain
fit up to a 120°C, that is going to be your target interference fit. Depending
on where your tolerances are, that
might be your maximum or minimum
target, with your bearing + housing tolerance
defining the other end.
Figure 2 Chart of the Equation Above. NSK Ltd, Cat. No. E728g 2009; p 69.
In my February post, I discussed
how to use hoop stress calculations to
determine how much the cup will grow
and shrink with moving temperatures.
Don’t make the rookie mistake of using
the 85 μm as your potential cup expansion;
your cup will only expand as far
as you compressed it. In a 25 mm wall
housing, most of the interference is going
to expand the housing wall, with
the cup only compressing by as little as
one-fifth of the overall interference.
Norm Parker is the bearing
technical specialist for
the driveline division at
General Motors LLC. Located
onsite at the Milford (MI)
Proving Grounds, he is
regularly tasked with testing
theoretical models in the
real world, in real time. With his bachelor and
master degrees in mechanical engineering
from Oakland University (Rochester, Michigan),
Parker has developed a keen interest in the
academic, commercial and engineering aspects
of the bearing industry. Prior to joining GM, he
rose through the ranks of traditional bearing
companies; by so doing he acquired invaluable
experience in working with some of the largest
customers — with the toughest applications
and demands — on the planet. Parker plans to
continue expanding his expertise and providing
substantial personal contributions to bearing
technology through metallurgy, design and
processing
Visit www.powertransmission.com/blog to read more of Norm's posts and stay
up-to-date on the latest in rolling bearing advice and technical tips.
