Components Motors Technical Articles
High-Power Density Motors
Introduction
This paper will discuss the trade-offs between power density, efficiency and cost for high-performance electric motors in order to help designers choose the appropriate technology for their specific application.
There are many terms that designers use to convey a specific requirement for an application which is similar in their goals — yet different when one considers the underlying technology goals.
When it comes to the selection of an actuator, we are often faced with the terms “small,” “light-weight,” and “high-power” — all of which imply that a solution is sought which will fit a specific requirement; but the technical implications of these terms are significantly different.
This article appeared in the February 2021 issue.
First, one very common misclassification is “high power,” which is often used when the designer is looking for high torque. It is important to remember that power (P) is the product of force (F) and motion (υ); or for a rotating machine torque (T) and angular velocity (ω). Thus, an actuator with very high-force/torque output will deliver no power if there is no motion, and a very small force/torque will generate a lot of power when the velocity is very high.
Hydraulic actuators generally will yield the highest torque/volume if the underlying infrastructure to generate the hydraulic pressure is ignored, but the velocity at which the force is delivered is typically very low. Thus, the actuator has very high-torque density, but low power density.
It should also be noted that, for an electric motor, the physical size is directly related to its torque output, although there are some potential tradeoffs between volume and efficiency that will be discussed later.
A second key consideration is the efficiency (υ), which is defined as the ratio of output power versus input power for a motor, and the inverse for a generator. Thus, a low-speed motor — even when it delivers a high-output force/torque — will always have low efficiency. Therefore actuators are often combined with a gear which allows the motor to operate at a higher speed and to operate at a higher efficiency, at which time the gear reduces the speed and increases the torque to match the application. Even though we lose some efficiency in the gear, this can significantly improve the overall performance of the actuator. A common example is the motor in a (gas-powered) car where we aim to operate the engine at maximum efficiency whenever possible.
The power and efficiency of a motor are directly related to the heat that is generated in the motor and which must be dissipated: the total heat losses (Ploss) are input power minus the output power:
We can now discuss the implication of these physical relationships and how they can be used to properly select a motor that will yield the best fit for a specific application.
Kollmorgen’s AKM2G servo motor is designed to deliver higher power and torque density in a smaller footprint so OEMs can substantially increase performance without changing motor mounting or using more machine space. (Photo courtesy Kollmorgen)
The Trade-Offs and How to Make Them Work for You
It is very common to have a customer call needing a motor or actuator, and when questioned about the detail they produce a complete set of machine drawings with a little black box space left open for the actuator, along with a set of specifications that cannot possibly be met, and all that at virtually no cost.
While there is no magic wand to fix this problem, there are some general avenues to explore in order to find a possible solution.
First, which motor technology to use? Brush DC motors, step motors and most AC induction motors are cost-effective, but they require more volume for a given torque and power than high-performance brushless PM motors; the latter are also significantly more efficient. Thus, we have less worry regarding what to do with the heat that these motors generate. The drawback is cost.
While brush DC and AC motors are often very cost-effective, a modern high-performance brushless motor with Neodymium magnets will be significantly more expensive. The high cost is partially offset by having less need for cooling infrastructure but typically, there will be a cost penalty for using brushless PM motors. One of the main cautions when using PM brushless motors with Neodymium magnets is that these magnets are typically very sensitive to temperature, and these motors can be easily damaged if they get too hot, which is especially true when lower-cost Neodymium magnet grades are used.
A trade-off solution is reluctance motors, which often offer better efficiency and smaller volume than brush and AC motors, but they may have lower efficiency and a larger footprint; although, at a significantly reduced cost — especially for high-volume OEM applications. Another advantage of reluctance motors is that they have no magnets and they typically operate at higher internal temperatures than PM brushless motors, but safety requirements may limit the allowable operating temperatures.
However, in many pump applications, where we have cooling via the load medium, i.e. — automotive water pumps — you may be able to operate at higher internal temperatures while still maintaining safe, external operating conditions.
An electric motor will change its operating efficiency with speed, but also with torque load. A lightly loaded motor is generally less-efficient than one operated at rated power, which is especially true for AC induction motors, shunt DC motors and reluctance motors. As load is increased, the motors will continue to produce the required torque, but their efficiency will generally drop.
This KinetiMax high-power-density motor from Allied Motion is an outer-rotor design brushless motor designed for high-torque, lowcogging applications like robotics, AGVs, and hand-held power tools. (Photo courtesy Allied Motion)
Thus, the heat generated will increase disproportionately with the load. Sometimes we can use this to our advantage; e.g. — if we have an application that only occasionally requires high-torque/power output for a short time with sufficient cooling periods in between, and where torque/power performance is more important than efficiency. In such cases we can use a lower-rated, smaller and less-expensive motor to meet these high-load conditions for short, intermittent periods of time.
The ratio of peak torque versus crated torque varies greatly with motor technology. Some brush motors have little margin while modern brushless motors can often provide 5x or more peak versus rated torque. Reluctance motors are somewhere in between, with a practical ratio 3x or more peak versus rate torque.
If the motor needs to stay cool or operate very efficiently, you may want to chase a larger physical size that dissipates more heat since efficiency is also a function of the internal heat in the motor (windings and magnets).
We have already discussed the use of gearing, which can also be an effective way to reduce the size of an actuator package, i.e. — traction drives, conveyor belts etc. It must be remembered that the efficiency of the gear will be almost constant (hopefully, around 90+ %). Thus, if we boost our motor efficiency from, say 60% for a direct drive to 90% for a geared system, our overall efficiency increases from 60% to over 80%, which means less heat and often a much smaller system as well. It is beyond the scope of this discussion to address all the details that will be encountered — backlash, etc. That may be a paper all by itself.
The above has so far been only a discussion of motor technologies that excluded the drivers, where applicable. Different drive electronics, PWM switching frequencies, excitation waveforms etc., will further impact the motor efficiency, higher speed performance peak versus rated torque performance and, most importantly, the overall system cost which is, again, a subject worth a separate paper in itself.
As we can see from this discussion, the trade-offs are many and the specific decisions are complex. Most engineers that use actuators in their design are often ill-equipped to fully understand all of these factors.
Suppliers can be helpful, especially if you work with a good rep that offers many different product lines, while manufacturers have a tendency to steer you towards a specific equipment solution which may or may not be the best fit for your requirements.
Another suggestion is to consult with your peers and listen to their input, as they may have encountered similar challenges in their design. Sometimes you may simply want to retain an experienced consultant to assist you with sorting through this maze and help you find the best fit for your application while avoiding costly mistakes.
As always, when it comes to motor and actuators, there simply is no silver bullet solution and it is important to consider all aspects of the application that may lend itself to different solutions.
George Holling is Technical Director of Rocky Mountain Technologies (george.holling@rockymountaintechnologies.com).
