Design Components Bearings Technical Articles Efficiency Load Motor Efficiency Power Torque
Application of Ceramics to NU-Type Cylindrical Roller Bearings for Machine Tool Main Spindles
Bearings used to support main spindles on machine tools must be capable of higher speed and greater rigidity. This is true in that any main spindle that turns together with a tool or work piece mounted onto it is one of the critical machine tool components that directly affects machining efficiency and accuracy of the machine tool; and, the bearings that support the main spindle are the most critical machine elements on the machine tool.
This article appeared in the December 2011 issue.
