ANCA Examines Benefits of Linear Motors
Growth in the global linear market is being driven by both increased demand across key industries and the clear advantages of linear motors over conventional motors. Within this segment, the contribution of ANCA Motion’s LinX M-Series linear motor has expanded the market and stands out above ball screw and flatbed motor options due to several design intricacies that simplify installation and use and push quality performance even further. Designed for function, the tubular construction of the LinX has several key benefits over flat linear motors.
Easy to install and retrofit
Simplicity is a key element of any great design and whether new or retrofitted, tubular linear motors are simple to install. Robust and thermally efficient they provide drop-in replacements for ball screw and pneumatic cylinders.
As an ideal replacement to retrofit pneumatic cylinders, the LinX M-series motors are optimized to ensure the minimum effort and impact to end customers. A key feature is that mechanically the motor is designed to be fully compatible with standard pneumatics accessories, such as mounting plates, linear guides and coupling pieces.
For retrofit projects, this means the LinX M-series motors can be easily integrated, while for new machines this allows machine builders access to a wide range of standard accessories.
Effortless retrofits contrast with the technical challenges usually presented when retrofitting traditional pneumatics with flatbed linear motors.
