Vesconite Lantern Rings Solve Hoover Dam Hydro Plant Corrosion Issues
When engineers at Hoover Dam determined that the original cast iron lantern rings built into some of its turbines needed to be replaced, they were looking for a solution to help them overcome the corrosion issues they experienced with the cast iron.
The maintenance team also faced another challenge. The Colorado River serves as a water source for the Hoover Dam hydropower station, and the water in this area is commonly referred to as "hard water" due to its high mineral content, specifically high levels of calcium and magnesium ions. Aluminium lantern rings that were first tried as a replacement, were corroded by chemical reactions with the minerals in the water.
Having used Vesconite Hilube bearing material in other applications, such as guides on their pressure relief valves, the engineers were familiar with the no-swell, non-corrosive properties of the material and also with Vesconite Bearings’ capability to create large-diameter parts such as these 44-inch diameter lantern rings (Ø1,100 mm). Vesconite Hilube also had the added advantage that it is not chemically attacked by the "hard water”.
Two lantern rings were supplied, one of which was divided into two segments and another of which was divided into three segments. Like the lantern rings Vesconite Bearings makes for pumps, the large-diameter hydroelectric power plant lantern rings were easily machined and included the necessary flush holes that would cool the shaft on which they were located.
