With this new generation, Sumitomo Drive Technologies has once again significantly increased the torque density of the gears, enhancing the internal structure while maintaining the same gear principle and external dimensions. The new ECY 203 and ECY 205 units deliver a more than 30 percent improvement in performance levels, in terms of nominal (rated) torque, acceleration torque, and emergency stop torque, compared with previous models. The maximum drive speed is up to 8,500 revolutions per minute, depending on the size.
Plug & play attachment to any motor
The ECY gears have also been upgraded in terms of flexibility. Thanks to a modular connection system, they can now be fitted to any motor directly at the factory. The modular gear input system enables short delivery times. The main body of the unit comes ex stock, with the flange assembly being based on the customer's requested input. Overall, the units' modularity helps boost the efficiency, flexibility, and cost-effectiveness of machinery and equipment.
"Our performance-enhanced generation of precision gears is based on a plug & play approach. The user benefits from a highly compact performance package that is ready for use. ECY shaft gears can be used in a wide range of demanding applications where exact positioning and high torsional stiffness are required. One standout feature is their ability to prevent ratcheting effects (i.e., unwanted teeth slippage). This is achieved by a significantly higher tooth contact area than cup-type gears," says Michael Berger, product manager motion control drives at Sumitomo Drive Technologies.
Bearings ensure high performance
