SKF Bushing Reduces Maintenance for Motorcycle Front Suspensions
SKF has developed a composite bushing for motorcycle front suspensions (or forks) that reduces the need for maintenance. A combination of metals, plus a lubricating coating, gives the bushing both mechanical strength and low friction.
“Motorcycle front forks typically require regular maintenance in order to ensure proper functionality,” says Nicolas Berruet, business development manager at SKF. “This bushing helps to overcome that and cuts maintenance to a minimum.”
Beyond reduced maintenance and low frictional properties under side load, the bushing offers a number of other benefits. These include:
• high load-carrying capacity.
• stability across a range of operating temperatures.
• small operating clearance, allowing improved guidance; and,
