Applications Wind Components Bearings Gear Drives Gearboxes Technical Articles MRO Wear
Premature Bearing Failures in Wind Gearboxes and White Etching Cracks
Wind turbine gearboxes are subjected to a wide variety of operating conditions, some of which may push the bearings beyond their limits. Damage may be done to the bearings, resulting in a specific premature failure mode known as white etching cracks (WEC), sometimes called brittle, short-life, early, abnormal or white structured flaking (WSF). Measures to make the bearings more robust in these operating conditions are discussed in this article.
This article appeared in the October 2014 issue.
