Liebherr Supply Slewing Bearing for Europe’s Largest Lifting Swing Bridge
Photo Caption: The inspection and approval of the individual rings of the combined roller and ball slewing bearing: (from left) Michael Sander (Liebherr-Components Biberach GmbH), Alexander Volgmann (DB InfraGo AG), Tobias Killmann (DR. SCHIPPKE + PARTNER mbB), Alexander Krölls (Adam Hörnig Baugesellschaft mbH & Co. KG, Matthias Längle (mlIng GmbH), Andreas Menzel (MCE GmbH), Ralf Hanke (Liebherr-Components GmbH).
This is what the Friesenbrücke will look like upon completion.
The Friesenbrücke is the key part of the 173-kilomet-long rail route between Groningen and Bremen. "With its total length of 335 meters, it is the largest lifting swing bridge in Europe, carrying not only rail traffic, but also footpaths and cycle lanes," says Alexander Volgmann from Deutsche Bahn. "The bridge spans the river Ems and opens the way for ships by rotating up to 90 degrees. This is where Liebherr’s slewing bearing and pinions come into play."
The combined roller and ball bearing along with eight matching pinions ensure that the bridge can rotate on its central pillar. "The technology used here is a lift-and-rotate mechanism. First, the rotating section of the bridge is unlocked. The central section is then lifted by the rotating pillar, releasing it. Finally, the hydraulic drive and the slewing bearing swivel the bridge," explains Karl Völkl from Hermann GmbH Maschinenbautechnologie, the supplier of the rotating pillar for the Friesenbrücke.
