Design Applications Automotive Components Automotive Gears Drives Gear Drives Gears Technical Articles Lubrication Power Power Loss
Is Splash Lubrication Compatible with Efficient Gear Units for High-Speed Applications
A thermo-mechanical model of a splash lubricated one-stage gear unit is presented. This system corresponds to a first step towards the design of a hybrid vehicle gearbox that can operate up to 40,000 rpm on its primary shaft. The numerical model is based on the thermal network method and takes into account power losses due to teeth friction, rolling-elements bearings and oil churning. Some calculations underline that oil churning causes a high amount of power loss. A simple method to reduce this source of power losses is presented, and its influence on the gear unit efficiency and its thermal capacity is computed.
This article appeared in the October 2015 issue.
