Hannover Messe Bearings Preview
PTE will feature a variety of new component technologies online for bearings, motors, couplings, brakes, gear drives, and motion control systems leading up to Hannover Messe 2023 in Germany. Here is a preview of some bearings suppliers to check out if you're planning on attending the event online or in-person in April.
NKE Austria (Hall 5, Stand B05)
NKE Austria GmbH will present bearings for wind turbine gearboxes and generators. The Austrian bearing manufacturer has more than 20 years of experience in the wind energy sector. NKE bearings have been installed in more than 4,000 wind turbines across Europe, the USA and China, equivalent to more than 10,000 MW of installed power.
"NKE bearings are used in the most important wind turbine components, that is gearboxes and generators, or as main bearings. We have final product approvals with major wind turbine manufacturers and are in the final stages of the approval process with others,” says Matthias Ortner, managing director of NKE in Steyr. "The strategic focus on sustainable technologies such as wind power and rail vehicles that was introduced three years ago is now bearing fruit. NKE is gaining a reputation as an innovative supplier of bearings for wind power.”
For example, NKE bearings are present in all bearing applications of the Envision gearbox: from the carrier (rotor side, generator side) to the high-speed shaft, including the intermediate shaft and planetary gearbox shafts. “For high-speed shafts, NKE cooperates with the customer’s engineering team to design bearings with enhanced profile and contact pressure,” says Michael Rössl of NKE’s Application Engineering department. “Another example are our new bearings with Power-Density technology: they are only 20 percent larger than conventional bearings, but they generate twice as much energy to optimize the output of the wind turbines and extract as much energy as possible from the air stream.”
