Grease Lubrication Mechanisms in Rolling Bearing Systems
Grease lubrication has clear advantages over oil lubrication: Grease does not leak easily; it has sealing properties; and it protects bearing surfaces from corrosion. Its disadvantages are grease-life limitations and a limited cooling ability. Moreover, in some applications there is a risk of grease starvation, which leads to reduced
lubricating films. However, if the right grease, sealing system and/or lubrication system are chosen, then grease lubrication offers clear benefits. This article summarizes aspects of grease lubrication mechanisms in rolling bearings.
