Drive Your Intralogistics Operations with Reliability and Efficiency
Regal Rexnord
Efficiency and uptime are vital within the intralogistics sector. Businesses require a partner who can improve sort accuracy and increase production to meet consumer demands. Regal Rexnord merges engineering expertise with industry-leading gearing brands, extensively used in the most challenging packaging and material handling applications.
Gear Drives
The Boston GearTM 700 SeriesTM and Grove Gear® IRONMAN® gear reducers are engineered to manage high-impact load applications efficiently, ensuring reliable performance to maximize your uptime. Both lines are designed to handle the grueling loads of intralogistics demands while protecting from contamination or overheating. With many sizes, ratios, and mounting configurations, Regal Rexnord’s portfolio of gear reducers can offer a compelling solution to your intralogistics mechanical power transmission needs. View the lineup here:
Gear Motors
Many operators find simplicity and efficiency when integrating the BauerTM Gear BS Series into their facility. Featuring helical gears with the high reduction ratios of worm gears results in smooth, quiet performance and high torque output. These geared motors are ideal for applications requiring precise speed control and compact design, such as conveyors, lifts, and packaging machinery. Renowned for their durability and reliability, they manage heavy loads with minimal maintenance, ensuring consistent performance. Discover the utility of the BS Series Here: or enhance energy efficiency by incorporating a Ultra-Premium Efficiency motor into your system design here.
Your Partner
Whatever your objectives or application challenges, Regal Rexnord Powertrain Solutions can help you achieve your unique goals. Every application relies on numerous components working together, but not all components are designed to function reliably and efficiently as a unit. Design experts from Powertrain Solutions provide the insight, experience, and expertise to engineer your collection of components into a fully optimized system, providing solutions that enhance efficiency, improve reliability and performance, reduce costs, and simplify ordering and logistics. To get started developing your optimized solution, visit here.
